More of the same with the large clip at the seat bottom.
Once you get it open, lift the flap and you’ll find some Velcro strips attached in the middle. Detach these.
Now you’re going to need to start pushing the skin up toward the top of the seat. You won’t be able to remove it entirely because it will be stuck under the headrest, which we’ll remove next.
Flip it over and you’ll see the foam pad.
Lift the foam pad and you’ll see a metal box. This whole assembly is what holds the headrests in place.
There are two plastic buttons just above the metal box. It helps to have another set of hands for this part. Push both buttons and have someone pull the headrest out of the seat back assembly.
Here’s a better look at what everything looks like without the cushion in the way.
Now we start on the headrest.
The two flaps at the bottom of the headrest just snap together. There’s a little groove in one flap, and a t-shaped tab in the other.
Seam pulled apart. Hecho en Mexico.
Carefully pull the material out from around the headrest pushbutton.
After that, all you do is pull the headrest internals out of the skin. Very easy. Here’s what you’re left with.
This was not made in America, or Mexico I would guess.
Reinstall the new cover, and your headrest is done. Then, back to the seat back.
Here’s the new Shelby skin installed. Don’t forget to lace the seatback release pull through the side of each seat so you can fold your seats down later.
Do that twice, and you’ll have a complete rear seat all done. Mine still had a few wrinkles in certain places, probably from being boxes up, but I think that will release over time with some good old fashioned Phoenix heat.
Then reinstall them in your car, and voila! Done!
Finally, you’ll have your old skins left over in case you ever want to return to stock, or sell them.
The whole job takes maybe a few hours. It's pretty darn easy I think. Definitely makes the interior look sharp. With the low cost and availability of takeoffs, it is definitely an excellent upgrade. You spend all your time in the interior, so might as well make it look nice.
Paul.
